Seat Belt Reminder Disable
Can someone point me to the thread that has the FORScan instructions to disable the seat belt reminder chime please? I've searched and can't find it. I tried the buckle three times, wait for light to flash and buckle again but it didn't work. Thank you!
@Nightshade can probably help you
I think I actually just found it.
Nightshade
Firefighter
Alberta, Canada
2024 Ford Explorer ST
It’s on the Explorer FORScan spreadsheet that I added in, but try this and report back. Only change where the 0 is, leave the x.
BCM -> 720-01-01 -> xxxx-xx0x-xxxx.
Tulsa, OK
You can do it without FORScan. It's pretty quick to do it. Just google how to turn off seat belt chime on Ford Explorer, and you'll find the sequence to follow. Last time I did it I had to do it twice to hold that setting.
Did you read my OP? I tried that several times and it didn’t work! Followed the sequence exactly. Turn on accessories, wait for light to go out, buckle and unbuckle three times, light should flash but it doesn’t. Tried it fast, tried it slow, nothing. It does say it won’t work with “My Key”, whatever that is.
Rick
Fort Hood, TX, USA
Rapid Red
That’s exactly what I tried but after three buckles/unbuckles the light didn’t come on. I’m going to try it again though.
Rick
Fort Hood, TX, USA
Rapid Red
3 buckles and unbuckle should work …some people have reported that they buckled and unbuckled 4 times and it worked
Not sure why it didn’t work the other day or on my first try just now but the second attempt seems to have worked. The light came on and then flashed after the fourth buckle/unbuckle. Thanks for everyone’s help!
Rick
Fort Hood, TX, USA
Rapid Red
(y)
Saint Paul, MN
Do you know if this works on the 2025, as well?
Nightshade
Firefighter
Alberta, Canada
It should, however my 25 isn’t in yet. Make sure to back up the module that needs to be changed so you can revert it back if it doesn’t work.
