2020 ST BRAKES
North Bergen, NJ, USA
2020 EXPLORER ST
Hi All,
I need help. I want to buy new brakes pads and rotors. What size are the rotors? In MILLIMETER 363MM OR 345 MM
This^^^^ Street Pack and Track Pack are the same size caliper and rotor, and they come from the factory red. Track Pack pads are different and expensive, but are a bit of a rarity. It's a pretty safe bet you have the Street Pack.
S
2020 EXPLORER ST
Thank you all for your help. If I remember correctly when I ordered the ST it came with street pack. and towing package. I'm planning on ordering from POWERSTOP.COM Any feed back on POWERSTOP?
djsparxlv
I have Powerstop on mine. Just remember to disconnect the battery before installing the rear calipers. That prevents problems with the EPB. Also, you will need a brake kit to spin the rotors in. They go clockwise or right hand rotation
That is incorrect. You put the car into Brake Service Mode and it automatically retracts the rear calipers then when you take it out of that mode it correctly sets the pad gap for the new pads. You don’t unhook the battery and you don’t use any tools to retract anything.
