Disable Auto Start/Stop on 2025 Explorer ST
Soulja4187
Soulja4187
Greenacres, FL USA
2025 Explorer ST and 2021 Mustang GT Premium
Thread Starter #21
How can I get the 2025 ST spreadsheets? Is there a function on FORScan that allows me to download the configuration settings? Some other settings I would like to set the auto stop/start feature to off, remove the turn signals noise (too loud), and turn off the seat belt reminders for the 2nd and 3rd row passenger seats.
I would love to get my hands on this as well.
FlatSpot
Atlanta, GA
If I can't figure out how to disable it using FORScan in the next month or two, I'll order it. Thanks for sharing!
JAX, FL
25 Explorer ST & 21 F150 PB
Seems much easier than taking the steering wheel apart like the 2020-2024 models. I may wait and see if they offer any holiday discounts next month or two in addition to feedback from others here.
PhilipW
Indiana
#26
I just got a 25 ST and my stop/start stays off as long as I unlock with my fob. I've only ever turned it off once and it's stayed off since.
I should state, I just like you guys hate the auto start/stop and just last week traded in a 2023 Kia Sorento Prestige Xline, which I hated and you had to click the button everytime you got in the car.
So, I pick my car up last week, first thing I do before leaving the dealership is click the button, go home set my profile up, play with the infotainment for a couple hours. Get in the car the next day and see the auto start/ stop button is lit and I go whoa, could it be, the car remembers I hate that and leaves it turned off... Well for a week now it's been off..
I'm browsing this forum tonight and see this thread, and now I'm wondering if it's a fluke? IDK
It could be the battery state of charge.
Soulja4187
Greenacres, FL USA
Thread Starter #29
Sumner County TN
2025 Ford Explorer ST 400a
#30
Did anyone not see thi post? This device disables Auto Start/Stop and lets you use youtube and other apps while in motion.
Ouch.... he only showed YouTube though. expensive....
Soulja4187
Greenacres, FL USA
Thread Starter #31
#33
If you keep it in sport mode, that would explain it.
Sumner County TN
#35
I watched it. But he only mentions bypassing ass and shows YouTube mirrored onto his screen. He doesn’t mention getting other things on the screen. Hardly worth $300 just to bypass ass and see YouTube is what I mean.
the forscan code works on some 25s and not on others.
i assume :eek: it has something to do with build dates
sport its OFF by default iirc
and in my 23 it shows a line through the A S S at start up then goes away, but in sport its there.?
below is for 2025s
Disable Auto Start/Stop PSCM730-03-01 xxxx xxxx x0xx IPC will have line through start stop icon - In sport mode the switch on center console will illuminate
change the 10th spot to 0
JAX, FL
#38
I had my '25 in sport mode yesterday and again forgot to turn ASS off. The engine turned off at a stop light. I'll get a picture next time of the IC showing both icons.
MOBandit
Grandview, MO
#40
Is there a way this can be disable. Its so annoying and I know this isnt good for the battery in the long run. Any help would be appreciate.
Thank you.
Not trying to start a firestorm, but the battery/charging system and starter are designed to work together for the Auto Stop/Start. I owned a 2017 F150 previous to my 2025 ST. I got used to the Auto Stop/Start...never turned it off. Starter never went out on it, battery was replaced at the six year point...which isn't bad for a battery in ANY vehicle. In other words, this may be annoying to you as a system in your car, but it has been designed for it, and it won't harm any of the components in your car if you leave it alone...
