Updated FORScan sheet for 2020+ Ford Explorer (All Trims)
#43
Start up chime? Should be available in the IPC easy way module, but can double check this week for you and get in touch!
I've been looking to get rid of the Start Up and Alarm On Exit, Do-do-Do, chimes but have been unsuccessful. I looked in the IPC and found several chimes but those are not there. I thought I read somewhere that they are located in the APIM so I looked there and found some chimes at 7D0-08-01 but I'm not sure if this is it. Right now the second digit is 0 which indicates all chimes are off but obviously they are not. Do you think you can look into this? I'm sure there are other who would like to turn off these chimes. Thank you!
FLnative
FL
#44
I did both of those earlier this week on my 2024 using the instructions in these two posts.
Double Horn Honk on Leaving Cabin
https://www.explorerst.org/threads/r2d2s-2022-st-kiss-build.5210/post-72450
Disable three start-up chimes
https://www.explorerst.org/threads/r2d2s-2022-st-kiss-build.5210/post-72956
#45
First off, thank you for posting this! However, two things: one is that the Double Honk On Leaving Cabin and the Do-do-Do chimes when you open the door with the vehicle running are different. I've already disabled the Double Honk. The second thing is in the second post. Where it says "Method" it shows only the second digit changed to a two but down below in the green and red boxes the fourth digit is changed from a three to a five. Which is correct?
I can look
Yours is what year
yes the 7DO-08-01 X0 xx is correct
you did the bcm change as well 726-63-02 xxx0
however i looked at my asbuilts and they dont reflect my vehicle
my first 4 digits are 4007
which indicates power mirrors Off, , 0 which turns off the chimes on door if engine is on,
and the next line moon light mode off? ad TPMS off, which is wrong as my TPMS is ON
i need to go look or listen to what my explorer does
FLnative
FL
#47
I only changed the second digit to a 2 and it updated the fourth digit after writing it. I think the fourth digit is a checksum.
The 3 do do do start up disabled
Shoukd also kill the door open do do do
Good catch
#49
Awesome! Thank you! I will give this a go today.
fireboy2669
Firefighter
West Virginia
Below is the link to the updated FORScan changes that is currently available for our 2020+ Ford Explorer and applies to all trims for those who don't have an ST. This one is for us, which helps compile all into one.
Keep in mind that the sheet will be updated by @powerboatr and @Nightshade (myself). If you're interested in something that isn't on the sheet yet, just reach out to myself or @powerboatr or comment on this thread.
LINK: https://docs.google.com/spreadsheet...ukfkgBqYkDE2w8imywaNF8VJF8/edit#gid=671029316
--DISCLAIMER; for those asking me regarding the turn signals to change from 3-clicks to let's say 5-clicks, it won't be possible. I looked into this myself and the issue is that the signal stalk on the 2020+ Explorers are using a slightly older stalk so issue isn't just software, but also hardware. So in saying this, changing the turn signals in FORScan will not be possible for the 2020+ Explorers for the unforeseeable future.
Hello, Is there anyway to increase the amount of times the turn signal blinks when you just bump the lever? I know some vehicles you can change it from 3 to 5 or 7!
#51
From what I've read, there is not an option for it.
Nightshade
Nightshade
Firefighter
Alberta, Canada
2024 Ford Explorer ST
Thread Starter #52
@BrooseDaMoose is correct. You can change it on 2025+ Explorers but for 2020-2024, you can’t. This is because the stalk being used in these models is outdated and there’s no values to change for it.
2021+ F-150s you can change the number of turn signals because of the updated stalk.
fireboy2669
Firefighter
West Virginia
Thank You!
