Go on their site and follow the directions on how to load it. It does require Windows and it is free. You’ll need to get what they call an “extended license” to use it. I turned off the double honk for when you walk away from the car while it’s running and hyper blink when I installed LED’s. You actually disable Bulb Out for left and right rear to do that.
Cool, I'll buy that and put it on one of my laptops, it will be worth it for the double honk alone, I hate that feature. Can you also make it default to Sport mode?
Easy. 10 minutes per side. From the inside of the back, there’s a small plastic cover opposite of the light assembly. Pop it off and unscrew the bolt assemply, then pop off the light assembly. Pretty self explanatory once you get into it.
