front signal wires
Sumner County TN
2025 Ford Explorer ST 400a
Anybody know the easiest way to tap the front signal lamp wires? Packed pretty tight in there.
I need to tap each side separately. Was hoping there was a harness easy to find.
Thanks in advance... :)
Jeppo
Davidson County, NC
I can’t help but, I’m curious about what you’re installing.
United States
Explorer ST
Bumping as I need to tap the front turn signal wires as well. Anyone have any luck with locating where to tap turn signals up front?
Westfield, NJ
Atb
At the headlight harness. Easily accessible once unplugged from the light.
rpankoe
Paramedic
New Britain, PA
Atb
I actually tried to test voltages here and couldn't find the turn signals. There's 12v+ on a wire, but the only one that fluctuated voltage on/off with turn signal wasn't 12v. It was only like .01v as the turn signal flashed. Since these are CANBUS, I'm not sure that it's there, or it's a positive ground or something else going on. Has anyone found the correct pin-out for the headlight connectors or where to get 12v+ under the hood for turn signals?
