I would imagine this would be accessories installed after the fact. Of course the PIU having a higher GVWR (and payload capacity) is Ford engineering anticipating that the PIU would need to carry additional gear than a retail Explorer.
But not all PIUs are outfitted with a lot of gear. A lot of ours were purchased due to cost and are used for investigative purposes rather than for reactive responses or working the road.
If you’re gonna do a RSB…and you definitely should…just do the Steeda or AFe or whatever. These cars like a lot of rear bar and any of the aftermarket options will net you better results than the still smallish PIU bar.
You can look it up right from the Ford Parts site, or do a search. It’s been brought up many times. If you don’t want a rusted out aftermarket bar, the PIU version is the way to go.
I’ve had a Steeda bar on since their very first run that looks as good as the day I installed it. Insinuating they will all rust is misleading at best.
