Won’t Start
Bullitt4305
Winchester, CA
Star White 2020 Ford Explorer ST
The other day, ignition took a couple seconds to turn over. Today, ignition wouldn’t turnover, headlights flashed, and got several messages ranging from 4wd and advance trac none op. Tried to jump start, no luck.
Appreciate the help in advance
23 Explorer ST
Sounds like you need a new battery
So does accessories come on and everything light up?
23 Explorer ST
Battery probably has enough juice to turn the accessories on but not enough to crank it.
How old is the battery?
Have it load tested. That will confirm if it is bad or not.
