Rear End Failure
I'm wondering if this is some kind of alignment issue (or rather misalignment) of the drive shaft , diff mounts, etc, basically everything connected to the diff. Unless you won the worst lottery and got two terribly defective rear diffs I'm at a loss. Where the bearings screwed at all, which could/would cause such issues.
Misalignment of the driveshaft to the diff would cause vibrations, noise, premature failure, wear, etc
I specifically asked my service department to check my driveshaft after 2 failed PTU's and RDU's. They found nothing with that but said the RDU had the wrong gear ratio. Mine is driving great now after a 4-wheel alignment and proper gear ratio differential.
Missouri
21 Explorer ST
My rear differential and transfer case/ptu were replaced back in early June at about 50,000 miles. The transfer case failed again just 3 months later. I think the differential is bad again too.
Just had my rear diff replaced again for a howling noise at 45 mph. My 21 has 35,000 miles on it. Only had 700 miles on the 1st rear diff replacement. Picked it up from the dealership, had a very bad vibration, jerking and "bucking". Took it back and now the transfer case is being replaced...wth
Dallas, TX
They put a diff from a 2.3L Explorer in your ST because they didn't know the difference. Probably a good thing the two have different gear ratios, if they were the same the service dept probably would have sent you on your way with the smaller diff.
