My 2020 ST started knocking 2 days ago on morning cold start.
MD
Good evening, all, I had my Explorer ST for almost 2 years and loving it until a few days ago. I have a bad knock right off idle up to 3500rpm. Wont do it under load, seems to run perfect but dont want to drive it if its a rod knock. Trying to get the dealer to pickup and diagnose. What you guys think ?
First things first…how much oil is in it.
Second things second…rod knock won’t go away as rpm goes up…it’ll get worse.
B
MD
Thank you thats what i thought, but it was a quart low when i checked, checked oil pressure with a obd scanner, it only 16.65 psi
B
MD
Okay started my truck this morning, to get ready for the dealership to pickup knock still there at idle, but not in gear and oil pressure 28.65 idling. Still going in for LH exhaust leak recall and hope they can figure out the knock
Eastern Tennessee
not necessarily true.
If the oil pump makes enough pressure and volume to float a bearing with excessive clearance, it may silence a knock when the revs come up.
40 years of building engines and I’ve never seen it happen. Seen other things quieten down as temps and pressures come up but never a straight rod knock. Anything is possible I suppose.
B
MD
Well it happened, vehicle started for the last time yesterday. Warmed my ST to get it moved for tow truck and it started, ran very smooth and chirped, shut off, wont turn over or anything now, so on its way to the dealership.
If it started quietly it wasn’t rod knock to start with…which could be a good thing. Post the updates as you get them.
B
MD
Will do, first Ford engine if it is after 40 years of Fords
B
MD
So it does look like the engine needs replacement, they are offering to buy it back and give a discount on a new. But for the first time in my life feeling bad about a Ford vehicle. Not sure what to do yet, have mostly owned Ford all my life.
23 Explorer ST
Man that sucks. I feel your pain about that.
I had a brand new Dodge Durango with a 5.7 Hemi and that engine was replaced twice in the first 8,000 miles. Lost my confidence in Chrysler.
Reason I have an Explorer now.
B
MD
Under pressure from my son, which left Ford to go with BMW and has stopped:unsure:
I've had literally almost everything but my engine replaced on my 2020 with 55,000 miles. So far all under warranty and free of charge.
