Thermal 3" + Cvf Downpipes
Shiver
boston
2021 explorer st
Check Engine light after Cvf downpipe!!
Need a space for the rear O2 Sensor.
Shiver
Shiver
boston
2021 explorer st
Shiver
Shiver
boston
2021 explorer st
Do I need to buy something to install?
Contact CVFab
“There are two defoulers in the box for the two lower o2 sensor holes on the cats themselves. It’s standard for any aftermarket high-flow downpipes from any brand.”
Shiver
Shiver
boston
2021 explorer st
Contact CVFab
Thank you for your help.:LOL::LOL:
fort lauderdale
2021 ford explorer st
Did any of you guys notice a loud rattling noise near the end of the mufflers when installing these CVFAB downpipes. I noticed immediately afterwards. Never had this noise before the downpipes. It's when I start up and reverse and while at low rpm's at slower speeds??
Shiver
Shiver
boston
2021 explorer st
Check the exhaust pipe rear end support hook. The sound caused by the friction between the hook and the plastic.
fort lauderdale
Okay
so check the rear end part of the exhaust where it's connected to the hangar. I did notice the drivers side exhaust was a bit more loose then before the DP.
South Carolina
Hangars should not be touching. I had the same problems when the idiots installed mine. It was very annoying.
fort lauderdale
Oh okay I see now. Thank you for the pic. This is what I needed. So the hangar is touching that bolt?? Also this is near the end of the exhaust?
South Carolina
Not touching the bolt. It’s just how the picture is (point of view). Hangar can go anywhere on it, just not touching where it angles down..
fort lauderdale
I crawled under there the other day. I see what you mean. Doesn't even come close to touching. I pretty much got the rattle to go away. Thanks again
