Tire pressure for 22" wheels
Westfield, NJ
Hi,
What tire pressures are you running with 22" wheels? 275/40R22, 315/35R22.
Thank you.
I run 33-34 cold running 295/40R22
nikolai9956
Westfield, NJ
Not too low? Aviator calls for 38 with 22s. I would like to run lower pressure for a little less harsh ride.
Your tires tell you what pressure they need, not the wheel size. Chalk them…read the contact patch…adjust pressure until it’s right.
I get even wear and a good chalk line. Agree with [mention]UNBROKEN [/mention], all tires are different and the chalk test is the best way.
