Did the Lincoln screen swap
Round Lake, IL USA
djsparxlv
Something like this? When you turn off the car this is what it shows. Now I have a Ford Explorer ST/ Navigator
You can change the startup screen in Forscan
Just an fyi, I was told today that the Aviator screen is now on national back order through Ford. Must be some interest in the swap
There’s plenty on eBay.
Jessup, MD, USA
I don't know if I got a defective unit or what, but the connector and the plug are very finicky. I have to push it up a certain way and it must not budge. Sometimes I get no screen on, and no touch, and have to wiggle the connector to make it work again.
Jessup, MD, USA
You can change the layout from Lincoln back to ST.
Press the right arrow button on the steering wheel and the right arrow button (Scan button) on the infotainment panel at the same time and hold them for five seconds. A new menu screen will appear.
The setting is under Theme. I have done it couple of time.
Do you have any pics of how this looks? Is this a permanent change once you do it?
Wisconsin
Unit Display LC52-10D885-UE Lincoln
Aviator 2020-2023
I have a 2024 ST. will this work/fit ? From the photo I see the vent dials. That is what I would like. Then I have to find the vent trim piece that will work on my 2024.
Jessup, MD, USA
Yes, it will work. Ford often has multiple part numbers for the same part. Sometimes it is a revision.
The Aviator display does work with the original vent from the 10" portrait version. I hear that there is better fitment and better access to the vent dials if you switch to the 8" version. Personally, I'm fine with the 10" vent.
Wisconsin
If anyone around the middle TN area is needing a lincoln screen for a swap I have a couple for $350 each I was going to use but changed my mind.
Howdy, Do you still have a lincoln screen available ? Would you ship ? USPS, UPS, FEDX ? I'm In Wisconsin Zip 53081 Thanks Can pay via PAYPAL or ZELLE
TN
I have one I can send but it will be end of the week before I get back and can send you one out
WCbx
Bronx, NY
