Hi,
1. Thinking of installing a differential brace on my 24 st. It has 1 bolt rear diff (3 bolt technically). Any advice of the brace? Is it really needed?
2. My st has infamous 38mph driveline vibraion when it's cold outside (below 45). If car sits outside overnight - vibration is present. If in the garage - no vibraion. Has anyone found a solution. Seems like it's related to grease settling when warm, solidifying, and causing slight imbalance in the driveshaft.
Thank you
Thank you
