I saw what you listed but you said you stopped short of taking the filter cover off since you said you could test it from behind "Was going to remove filter cover, but didn't think there was a point being I was able to test it from behind battery." which is a little confusing because are you talking about the recirculation flap or the cover that holds the filter in on the glove box side? To me it sounded like you did not actually take the filter out and if you did not there could also be something stuck under the filter like a screw or something? (just thought of this) or the filter itself is not sitting in there properly, however if ya did take the filter out and check it all then I got no other thoughts.
I know its not a screw loose. Although I rattle my head sometimes and hear them.
But seriously, If I really thought it was, I’d remove it. Raining, I was lucky to get that far. Weather has been a pain.
I move at a very slow speed on flat ground wouldn’t rattle anything like that. Something is twisting, turning or moving up and down.
That video I posted on that older model showed some clues. Other things I’ve been hearing is that the pressure tube inside shock rattles. Again, I don’t buy that. Nor do I care. I just want it fixed. Bad enough I do all my own computer crap. I’m not going crazy on mechanics any further than I have.
I got to get an in-depth conversation with my service writer. By now, his tech should have been able to examine the ‘24 strut they replaced by now. They need to explain to me WHY they cannot hear it with or without their sniffer. The owner of that 24 heard it and brought it back after the dealer said they fixed it. They poked and hoped it was the sway bar and other stuff.
They ended up replacing stuff they didn’t have to and really pist their customer off.
Bottom line, new strut fixed it.
