2025 Ford Explorer ST Front End Popping Noises at Low Speeds
Birmingham, AL
I recently have put roughly 3700 miles on my 2025 Ford Explorer ST and started noticing a popping noise coming from the front end of my 2025 Ford Explorer. I can feel the popping noise in the cab as well. It only happens on bumps and around 5-40 MPH. It almost reminds of a sway bar or linkage issue, but I was going to see if anybody else might have had these issues. Thank you for your help in advance.
Sumner County TN
2024 Ranger Raptor
Rattling | Page 2 | Explorer ST Forum read up.....
California
I hear a small pop when turning the wheel to the right from my front left but its not a loud and I don't feel it at all. I figured it was the suspension or something getting settles or its just a brake line or something moving a bit. I took a look but did not see anything loose etc... on mine and for me it's barely noticeable so I don't think its a issue and I just hit 2,062 miles and so far drives like a dream. Maybe have the dealer check yours.
Ford designed the 6th generation Explorer to look tougher than any previous one but unfortunately it's not engineered to be very tough. In fact, after owning 5 sedans previously, this was my first truck ever and it's really pretty flimsy and downright fragile after only 55,000 miles on mine. I've had to have pretty much every major component repaired or replaced, except the engine.
MMbeer
Firefighter
Belmont
We have the same noise the vehicle is at the dealership now but no word yet. Will keep you posted.
JAX, FL
25 Explorer ST & 21 F150 PB
In the last week (~3800 miles) started to notice an occasional weird noise from the front at slow speeds when going straight that sounds like tumbling wood or like a solid front axle truck suspension wobbling.
C
Birmingham, AL
I wanted to follow up with you and see if the dealership had any luck locating the issue. Thank you for your post!
23 Explorer ST
I have an appointment next Thursday to have the struts replaced on my 23 ST. Popping/clunking noise at low speeds in the front end is getting worse each day.
Charlotte
Just had my front struts and mounts replaced. I posted in another similar thread about it. 24' under 2K miles. Warranty repaired, dealer noted "excessive wear".
pgk1
2025 Ford Explorer Platinum 3.0
Didn't they have a bulletin on the front struts starting on the 2023 model years?
SoySauceSoakedSaltine
South Carolina
Yea I got something loose in the engine compartment what sounds like something is rolling around and fluttering in the wind at 50+.
JAX, FL
They are replacing the drivers side upper strut mount.
Sumner County TN
2024 Ranger Raptor
Let us know if it resolves your problem. I'm still fighting with my dealer that cannot seem to hear the noise.
23 Explorer ST
My Explorer has been at the dealership since last Thursday and it’s still sitting out back and hasn’t moved!
Service writer said they are a little behind replacing struts. There was four explorers the tech was working on now for the same thing.
At least they gave me a 2024 F-150 loaner to drive.
Hopefully I’ll get my ST back by the end of the week.
Charlotte
Seems at this point ford should be doing a front strut recall. Must have been one hell of a huge bad batch.
Had to have mine done as well with 500 miles on the clock...
23 Explorer ST
Agree!!
JAX, FL
It's been in the shop all week waiting for a new strut to come in. They are saying hopefully early next week.
