2025 ST test mules for forascn changes
2025 Explorer ST Line
#41
With the changes to APIM 7D0-09-05, do you still have lane keep/centering and blue cruise working? One or more of the 5 mods I did to APIM led to those drive assistance features disappearing even though enabled in settings.
Also it added this to the settings screen, but I can’t figure out how to make the option useable.
Canada
#42
I got Walk Away lock working. However there is no horn chip and in the vehicle settings under Locks, walk away lock is greyed out and says disabled. It does work but doesn’t chip the horn for
Someone on Facebook had posted to change the following values: under APIM change 7D0-09-05 to 0015 8060 20FA and under BCM change: 726-89-02 to 0101 0101 01BD
I made those and it locks when walking away and flashes the parking lamps. Just would like to figure out the horn chip for confirmation.
I attempted these changes as well and can confirm that the walk-away lock works with the lights flashing for confirmation. Audible confirmation does not work.
Canada
#43
Also enabled welcome lights on approaching the vehicle with the keyfob. Confirmed to be working.
#44
Nice! I will give this a try. I didn’t try that one yet.
Canada
#45
I got the global window close (for front windows) to work. It works by double pressing the lock button on the fob and holding on the second press. This process did not work per the factory settings as only global open worked when enabled in the settings>Vehicle>Windows.
Here are the forscan changes I did for it to work
Changed the below options in BdyCM from Disabled to Enabled
BCMGlobal Close - Initial Value
BCMGlobal Close - Personal 1
BCMGlobal Close - Personal 2
BCMGlobal Close - Personal 3
BCMGlobal Close - Personal 4
BCMGlobal Close
#47
To turn on horn beep for Walk Away Lock. BCM change 726-89-01 to: 0101 0101 01xx
Canada
#48
I'll test this as well.
If you open the rear hatch after turning off the engine and then walk away after closing the hatch, does the walk-away lock still work? It does not work for me in this scenario.
Canada
#49
Confirmed. Walk away lock horn chirp is working after those changes to BCM
Sent from my SM-S918W using Tapatalk
#50
Opening the hatch after turning off and then closing while walking away does not work for me either. Which might be OK, because I usually hit the close and lock button at same time when closing hatch.
Canada
#51
Now that I think about it, I hit the lock and close hatch button before walking away as well. The only reason I didn't press lock is because I was testing the walk away lock function.
