2025 car. What mods should I avoid because the ECU hasn’t been cracked
Ldstang50
FL
As the title states, what mods should I NOT do until the ECU is cracked?
In the mean time, what mods should I be doing?
In just my brief driving, it feels soft, body roll and some slack in the driveline. I’ve heard/ rear sway bar, trans mount insert, diff brace, subframe insert, diff bolts, rear vertical links, subframe lockout. Besides stiffening things up, they could be reenforcing weak points for the future
I just ordered the UPR catch can and hitch cover from Zeus
Thanks to @2020FordRaptor for the advice/suggestions
https://www.explorerst.org/threads/explorer-st-modding-101-guide.7324/
Thank you in advance
NJ
ForzaMotorworks for parts - excellent experience working with Alec from there on all of my aftermarket parts.
I think you are off to a good start so far. I'd also add the fenfab v2 intakes and the Thermal 3inch catback. Eariler today I noticed Forza is still running their holiday sale on Thermal.
Enjoy your new ride!
Glad I could be of assistance. There’s no parts you’ll need to avoid, none require tuning,
You can add pretty much anything you want excluding fuel system or turbo upgrades. It won’t make any more power to speak of but the car will run just fine.
North West
Suspension parts will help with how it rides. Fenfab makes a lot of parts to help the suspension. A rear sway bar will also help.
