Steeda Subframe bushings
Yenko
Milford, CT
They are the same. Not sure on price difference. Either you're supporting a major player in the Ford modifying community or a small business that has been supporting this Explorer since day one. Can't go wrong either way.
Thank you
Louisiana
Get the FenFab bushings. There is a $0.05 difference in price at Leathal Performance. But you could just go right to the FenFab website and support the small guy.
This x1000. No one is working for free and the more people that touch your transaction, the more some small cut of the money gets diverted off to a 3rd/4th/5th party before it reaches the maker. Support the people doing the work you appreciate as much as you can.
Jessup, MD, USA
#83
I just put these in, was very easy. So far I've only taken it around the block, but I can already feel a difference.
Have you ever rode a skateboard that had the trucks too loose, and then tightened them? That's what it feels like now. Much better.
BeyondEOD
Active Duty U.S. Air Force
Missouri
I’m going to pull my Steeda front diff bushings and reinstall the factory ones. Also looking to go from an AWR brace to the ID Speed brace to help with the noise I have.
Yes they are failing and have been. It was always a bad idea…I’ve been saying it since they came out but everyone thinks the diff has to be damn near solid mounted and it’s just not true. You also can’t side load a poly bushing flange like that…and now everyone sees why.
BeyondEOD
Missouri
Let’s make a delrin set….;)
Socal
#88
So are the steeda bushing kit not good for it?
Or are they still worth the buy with the fenfab toe and vertical links?
Steeda subframe bushing kits help with no downside imo. I agree with [mention]UNBROKEN [/mention] on mounting the diff too solidly.
