SPD Install completed last night and according to my Mechanic, no CEL.
He did say there was a fitment issue from the stock downpipes being threaded and the SPD's NOT being threaded in the connection between the SPD's and Borla just not being designed with each other in mind. He had to fabricate/modify/lubricate the fitting to get it flush and not rattle because of the tight fitment.
**Anyone else have this issue??**
Also he said there's a little noise (barely noticeable - have to really strain to hear it with windows up) coming from the flex-pipe on a cold start for 2 seconds , then it goes away.
Also in between 4th and 6th gear when you feather the throttle between 2,000 - 3,000 RPM's at 50- 70 mph a barely audible noise.
*Hoping the tune may address the noise and will mention to Adam @ZFGracing when we work on the next tune.
Waiting for XPel and Ceramic Coating to get done before I pick it up and will update the thread when hopefully there is some improvement/development.
Sent from my SM-N986U using Tapatalk
