2025 ST test mules for forascn changes
2025 Explorer ST Line
#61
Interesting
which line item under the apim 7do-09-03
Im wondering if it would add the option under the Power Gate Hands Free in the settings if enabled. I haven’t messed with it yet.
#62
Has anyone figured out auto stop/start disable yet?
2025 ST-Line
#63
Hey all. New here. So I used forscan on my '24 GT with no issues. Just tried hooking up to the new '25 explorer, and it's saying has a custom tune on PCM and to enter code. What am I missing here? It recognized my GT right away.
Do I need a different plug for some reason?
Thread Starter #64
do you have a custom pcm tune? i know thats unlikely but had to ask
make sure you have the most up to date forscan
https://forscan.org/download.html v2 3.64
what obd connector are you using
if its blue tooth
remove any saved items in the bluetooth thing , and retry
for reliability the best way to do forscan is a cabled obd vice bluetooth for information
2025 ST-Line
#65
if its blue tooth
I wouldn't think so, as I just bought it from dealership new with 6 miles on it the other day.
Not using Bluetooth. Using OBDLinkEX.
I'll check the version of forscan, but assumed it was latest as I just did everything on my GT last month.
2025 ST-Line
#66
Ok, checked and have the latest version. This is the error I'm receiving with regards to the tune. 20250105_115707.jpg
#67
Ok, checked and have the latest version. This is the error I'm receiving with regards to the tune. View attachment 27222
You’ll need to contact Forscan. I had this issue. I emailed them my VIN and debug logs within a few hours they sent me a beta version of Forscan.
Thread Starter #68
yup what he said
we did the simple stuff
now do step 2 (y)
they are pretty quick on a turnaround
let us know the outcome
2025 ST-Line
#69
Thank you both for the info. Will do.
#71
Is anybody noticing that the walk-away lock function isn't 100% reliable?
If it is just me and I park and immediately leave, it works almost all the time. But, if my kid is in the back it doesn't seem to work.
Also, the touch-handle to lock function seems way less functional now. I'll touch it multiple times before it finally locks sometimes.
#72
I have noticed it’s intermittent at times. As you said if it’s just me, locks fine. If I’m opening and closing doors few times then it’s not working. If I close my door before my passenger and then they close the theirs, it won’t lock. I haven’t noticed any passive entry issues, however there is a TSB for the RKE and passive entry.
