Full Build Agate 2020 Explorer ST
This is my full build currently with updates as they happen... or are finalized, I should say. I'll get into the process of how it got here eventually.
Here goes:
  • Nostrum High Performance
    • Stage 3 injectors
    • Goliath Fuel Pump
  • ZFG Racing e60
  • Fenfab
    • Hot and Cold pipes
    • Toe links
    • Downpipes
    • Full custom 3" exhaust
    • V2 intake (new)
    • Baffled oil pan (new)
  • CRP Stage 5 turbos
  • Suncoast stage 1 transmission build kit
  • Meziere Flex Plate
  • Circle D torque converter 2800 stall
  • Whipple intercooler
  • Steeda
    • rear sway bar
    • end links
    • subframe bushings
  • FV coil overs
    • racing setup with 18kg springs
  • Gram Lite 18x10.5 with 305/45r18 Micky Thompson Street R's
  • Velossatech big mouth ram air with lit kit (can't forget this)
I'm sure I'm forgetting some things. Hopefully I'll have a better list when I actually get the car back. It's currently at Nostrum High Performance getting a new ZFG engine and new CRP Turbos
Here's my favorite pic from the 2023 Shootout in Ohio, last track slip and most current dyno sheet. Track and dragy times are all at about 660hp
Wow! Very impressive build list and numbers. Welcome to the forum!
J
Thank you! I've been meaning to do this for.... 3 years. Better late than never!
