JXB bushing insert
Even though the deceleration whine isn't as loud as it was (for whatever reason), I still plan to remove the JXB inserts (on my 4 bolt) next chance I get. I don't notice any benefits and there are some unanswered questions in my mind. Like what does stiffening the rear do to the front of the diff? What does the significant loss of threads into the diff cover for the bolts do for the reliability--especially the drivers' side insert which sticks out a lot further? Too often, we enthusiasts mod with good intentions but ending up shooting ourselves in the foot.
Just a pic showing thread markings. The upgraded bolt on the left was removed from passenger side mount with JXB insert. The other two are OE bolts from passenger side and driver side respectively with no JXB inserts. As anticipated, the bolts with the JXB inserts do not thread into the diff cover as much. Whether this is a concern s anyone's guess.
Jessup, MD, USA
#83
I know this part helps with launches. Is there a noticeable improvement when just daily driving? I recently did the subframe inserts and could feel an immediate improvement even just driving around.
Subframe inserts are definitely good. I don't notice anything with the JXB inserts except the noise...and not just the whine--there definitely knocking sounds too. It's almost a relief to have these removed. If you think the insert is just filling in the voids of the bushing, think again. The end of the bolts are banging against the body of the inserts which bangs against the collar of the subframe.
I gained no additional noise with the JXB inserts (4-bolt, no diff brace). None at all. But I did notice more immediate response in the diff. I think they are a great idea for any Explorer.
