4WD or AWD?
I've done a ton of searching and reading on this and I still don't understand. Everything I have on my vehicle (window sticker, specs sheet, owners manual and dash display) all say it's 4WD. The explanation of the system on the Ford site says it's 4WD. But in so many other places it says it's AWD. Based on my knowledge of how the systems work, it appears to be 4WD. I don't see any difference from the older models with automatic 4WD other than it monitors a lot more information. An AWD continuously send torque to both the front and rear wheels. The 98 Explorer I had was AWD and it basically just didn't have an actuator to connect/disconnect the transfer case to the transmission. My moms 07 Freestyle is AWD and it has a CVT (Continuously Variable Transmission) which distributes torque to all four wheel. So, what am I missing here? I think this is just a matter of terminology and not technology.
Clear Lake
2025 Explorer
Good question! I have been wondering about the same thing.
It definitely is technology. Our cars are AWD. Automatic or Intelligent 4wd is AWD. Some marketing person at corporate has caused this confusion. There are different transfer cases that utilize different ways of using AWD. 4wd utilizes a transfer case that forces the car to be in 4wd high, 4wd low, or 2wd all the time. AWD is electronically controlled, with usually no user input, and usually uses a series of clutches to send a certain amount of power (it usually varies) to the front or rear wheels. Most of the time, newer AWD cars will automotically disconnect the front or rear wheels under low-load circumstances for efficiency. Our cars use different actuators and clutches to disconnect or increase the power sent to the front wheels.
North West
I wouldn't say it's definately technology. I'd say it's both. Ford called their 2nd generation Explorer AWD but it was basically just locked in 4WD high. The transfer case just didn't have an actuator. Not all 4WD vehicles had 2WD, 4WD High and 4WD Low. When they came out with the automatic 4WD it was either 2WD or 4WD High. The Explorer ST is kind of the same. The transfer case (or PTU as it's called) is just more advanced. I had an Eagle Talon (which was based on the Mitsubishi Galant) and it was true AWD. There was no transfer case. It had a viscous coupling, (a fluid-filled coupling that automatically adjusts power distribution based on wheel slip), in place of a regular transmission. The Freestyle AWD that @BrooseDaMoose is talking about used a similar set up. The Explorer ST does have a wet clutch but that doesn't make it AWD. Torque is not distributed to the individual wheels by the transfer case. All it does is distribute the torque between the front and rear differentials. The differentials are also "open" differentials so the display you see in the dash is not correct. Torque is not equally applied to all four wheels at the same time.
I was afraid of this. It depends who you talk to or what site you visit as to whether it’s 4WD or AWD. While I agree with some of the above, I don’t think it’s all correct. I did see the transfer case referred to as a PTU (Power Transfer Unit) in a few places. Maybe that’s why some say it’s AWD. I’ll just have to dig into it more. I can say, the first issue I had with my vehicle was that the actuator got stuck. I had a C00A6 - 4WD/AWD Transfer Case Unit Actuator code stating “Actuator Stuck”. It was stuck in the locked position. Whenever I made a turn, it felt just like my Ranger feels when making a turn while in 4WD. Like the inside wheel is slipping. Not sure how else to explain it other than it just felt “rough”. If anyone has a good explanation of how the transfer case (or PTU) works or knows a site that explains it, please share. I’m really curious about how it works.
I found a couple good reads on Car and Driver that explains AWD and 4WD systems.
AWD vs. 4WD
AWD Systems Explained
The only thing throwing me off is what they mention as "unnerving shudder" when the system binds up. That's what I was trying to describe that was happening when my actuator got stuck. However, I'm leaning more towards the AWD side.
Tomatoe. Tomatooo
It's awd for all intents
Watch the power distribution thing in the IPC
Front is indicating they get tq or power almost all rhe time
Even at highway speeds if you accelerate a small bit
It's a full time one speed trans case...no neutral..which is weird..because explorer is perfect size to be used as recreational towing 4 down behind a motorhome
The computer applies or removes tq to any wheel
And applies or removes clutch pressures as needed to distribute tq to wheels
My 22 f150 had 2 speed t case with a 4Auto setting..which engaged front end very similar to what the st does..puts tq to front all the time .
Makes for a very stable sporty drive on curvy roads.
Ford needs to get the labeling right and stop using 10 different definitions.
My insurance company lists it as AWD snd thus discount over 2WD models.
For me...it does not matter
As the computer ensures the wheels that slip...don't get the same tq
And car xoom zooms
Exactly what don't you agree with?
The part about Automatic 4WD being kind of the same as our Explorer ST's. The PTU is nothing like a transfer case in an old gen 2 Explorer.
I'm just confused about one thing. If it's a full time transfer case, what is the actuator for? I though it connected and disconnected the transfer case from the transmission.
North West
It's not full time. The 4WD Actuator does exactly what you said. And I didn't say the transfer cases were the same! I said they were KIND OF the same. The one major difference is that the ST's PTU can adjust how much torque goes to the front. The older transfer case was a 50/50 split.
To an old school guy like me, I describe it more as computer controlled 4wd, and not the traditional old school 4wd. To me, an awd is full time viscous coupling, no clutch, awd. Like the original Audi Quattro drive which is outstanding. No interaction required, person or computer, as it automatically adjusts torque at each wheel. To me, the ST is more an auto 4wd that requires mechanical interaction to alter torque. Both front and rear diffs are open and not lockers. Meaning both wheels are not driven at the same time. The only way to get torque from a slipping wheel to the non slipping wheel is to apply the brake to the slipping wheel or to engage the clutch in the Ptu to send more power to the front.
Nebraska
The line between AWD and FWD/4X4 is pretty blurred today. Originally 4WD was the rugged offroad driving all four wheels mechanical drivetrain, the first grandaddy system. High range, low range, and 2WD. Then AWD came around, which seemed to be used when cars started driving all four wheels (not counting AMC which is a different animal). Back in the 1980's when the Tempo and Topaz had it, it was called All Wheel Drive. Now all systems are high tech mechanical with electronics.
I think rather than differentiating the mechanical components and technology, it refers more to the purpose of the vehicle. Vehicles that say AWD are for use on the roads only, not for off roading. Ones that say 4WD/4X4 are able to go offroad to some extent. Of course, the definition of offroad may be a gravel road to one person and rock climbing to another. Our Explorers have the trail mode, which I guess would qualify as off road, but I wouldn't take it rock climbing. Something like an Edge, Escape, or Fusion are AWD and I wouldn't take them far off road. Not sure if rear drive factors in, but maybe it does if the previous FWD based chassis Explorer was called AWD.
The only differences between the early Explorer AWD and 4WD was the deletion of the transfer case actuator and it had no low range.
Me to...what does the actuator do?
Is it to control clutches or shift to engage front end?
It's a mystery,
My thinking based on how it all works, is it controls clutch engagement or the like
It's definitely not our dad's oldsmobile in the way it works
I have seen the display on power distribution..show almost equal readings to front and rear when I press go pedal aggressively.
Agree on not taking the st. Rock crawling
It's just tooo low..
But slippery mode
Works very well, so far
This is what I thought. It work much like the older style 4WD's only the transfer case (or PTU) does not. It uses a wet clutch system to adjust how much torque goes to the front like an AWD does with a CVT or coupling. Torque is definately not sent to each wheel as the display indicates though. It would need lockers or LSD's to do that. When I built my first V8 Ranger I used a 99 Explorer for the swap and it was considered AWD. But it was basically the same as the push button 4WD's only it didn't have a button for 4WD because there was no actuator to lock the TC to the transmission. It was permenantly locked to the transmission. Now I'm leaning more towards it being closer to 4WD than AWD.
ExplorerSTLine
Pennsylvania
2025 Explorer ST-Line
Are the following statements correct:
1. Even though it says 4WD it is actually All Wheel Drive.
2. The All Wheel Drive kicks in automatically when needed.
3. When you select "slippery mode" it forces the car into AWD and lowers throttle response and optimizes shifting.
So much to learn - so little time!
If you are driving on the highway you are essentially in one wheel drive as only one rear wheel is being driven and the front is disengaged. If slip is detected, the front differential is engaged but only one wheel in front and one wheel in back. From there it only engages the other wheel on the axle by braking the slipping wheel. So technically, the best it gets at any given instant is two wheel drive, one front and one back. When active, the abs is monitoring wheel spin and applies the brake on the slipping wheel to start driving the wheel on the other side. In a true AWD system, all wheels are driven at all times and the viscous couplings distribute torque 100% of the time automatically.
At least that is my understanding of the operation. IMO it is not and never has been AWD.
Thread Starter #19
Excellent explaination! Thank you!
North West
You nailed it. I don't know why it's so hard for people to understand! It's a Ford product, designed by Ford engineers and they label it as 4WD because that's exactly what it is. Period!
