E50 ZFGR tune 558 whp and 11.32 @120 full weight draggy!
Marinette, WI, USA
558 rwhp stock turbos and stock fuel system! Really enjoyed working with John on this and him giving me some extra time to play with few things I've wanted to try to get down in the there and get the small hp gains from few different places!
Yes this is an awd st with the transfer case unplugged for the dyno.
https://www.facebook.com/share/p/18gTuKD3mx/
Sent from my SM-S928U1 using Tapatalk
What do you mean by unplug the transfer case? Some sort of electronic stuff you disconnect or did you physically do something?
ZFGracing
Marinette, WI, USA
Unplugging the electrical connector that goes into the transfer case. This is very risky because if the actuator isn't fully disengaged you can burn the clutches out.
Dominican Republic
Ford Explorer ST 2022
Maybe 520 AWD?
Would be interesting to know where you got the extra little HP gains.
ZFGracing
Marinette, WI, USA
No, I think it would actually make more on an awd dyno with more load. His stock tune only made 320 hp and typically we see 330-340 on an awd dyno.
And I have even less doubt about that because it trapped 121mph full weight.
Dominican Republic
You are right yesterday put down 359awhp in mustang dyno (stock only 93oct VP + E10 Vp X85) 5 gear, 1:1 is seven but people always say 4 gear or 5 gear
