Sync 3 to Sync 4 upgrade
Dpratt202
Los Angeles, CA, USA
2020 Ford Explorer
Hi, I upgraded my sync 3 to sync 4 screen and APIM. I have prowled the forums to see if I can find some changes in Forscan to make. However, I wasn’t able to have any luck. After running a VIN scan, I see that the APIM is from a Lincoln Navigator. I have made changes in Forscan and have some knowledge of using it, but any help would be greatly appreciated.
Im having the following issues with the swap;
  • HVAC fan speed is only controlled by the AUTO button and not by the knob on the screen.
  • Rear HVAC controls are non-functioning.
  • Volume is displayed at zero no matter what volume it is set to.
  • Fordpass is not working
KoolAl44
Alabama
You need to find a spreadsheet for the navigator apim blocks or get a apim from a f150 that has the 12inch screen. The f150 apim would be more common
