Winter warriors?
23 Explorer ST
Rapid Red Explorer ST
Interesting that Tire rack says this and all other 18” rims do not fit.
These are 25mm offset which I think will not work? But yes, it thinks the st can have 20s or 21s only. I’m trying to find some winter wheels
18x9 +35
Thank you for the response. Do these at 25mm offset work with the st? Would the tires end up 10mm further out from the centerline of the vehicle?
I am a complete novice at this. Just got the same red one you have, yours looks sick AF
23 Explorer ST
Thanks man, I believe a +25 may cause rubbing when turning lock to lock.
