Interceptor amber DRL's on Explorer St
2023 Ford Explorer Timberline
Hi everyone, I drive a 2023 Explorer Timberline. I am wanting to have the front turn signals to act as parking lights as well. I don't want them as DRL, but I do want them if the parking lights are on or headlights are on. Still want them to act as turn signals as well. Anyone know how to accomplish that?
cmaybury
Melbourne
2020 Ford Explorer
Correct, i made a post on this earlier back in January, I have mines configured to where During the day the ambers stay on, and the white trim lights are set to "0" brightness, but at night the ambers stay on as well, but dont flash when you flip the turn signal switch left or right in the front. The ambers in the rear of the vehicle flash at night once you flip the turn signal on, but mines is set to where when the headlamps are on, the ambers are "locked" in place from the front, and only flash in the rear, not the front. However when the headlamps are off, both front and rear flash at the turn signal switch, and the front ambers resume position to both stay on once the left or right turn has been made. I can share my configuration from my vehicle to anyone if you want it, and either just play around with them on your own liking. Im still trying to find a way to configure the high beams to flash as police lights do, as my vehicle is being used for 1st responder purposes.
Can you share the configuration with me please?
The DRLs are just brighter than the parking lights. DrLs and parking lights use the same LED strip along the top of the headlights.
My DRLs are the white strip and the amber turn signals are below it. I want to make the amber turn signals to also act as parking lights. Currently there are no forward facing parking lights (this is factory, didn't even know that was legal to not have that)
Yes there are, the LED strip dims to act as a parking light if set on that setting.
I see, you are correct, sorry about that, never realized.
Whenever I make the front turning lamps set to Turn and Position, they do not work as turn. As mentioned by another it is probably something to do with the brightness. Anyone figure out how to make the front turning lamps be dim for Position?
Nightshade
Firefighter
Alberta, Canada
2024 Ford Explorer ST
My 2025 ST hasn’t came in yet to test and verify this but for those with the 2025s already; confirm if the same values for the 2021-24 Explorers for amber DRL works on the 2025 Explorers? I’ve already had 2 people confirm, would like to know if anyone else has done it yet?
Values are:
BCM -> 726-42-01 -> x4x4 xxxx xx— (Sets the White
DRL to fixed position (off when the car is in normal drive mode during daytime)
BCM -> 726-43-01 -> x1x1 xxxx xx— (Sets Turn to Turn and DRL)
Virginia
Values are:
Haven't done it to mine yet but I saw a 25 on the road last week who had enabled amber DRLs...
St. Louis
That's cool you saw a 25 in the wild. I have not seen one other than mine.
Forscan is able to be used on 25s?
Virginia
Yes, I'm trying it out today.
Virginia
Amber DRL edits worked fine on the 25. Does anyone know if you can set the parking lights to amber too? They revert to the white strips. It may have been covered in the thread...I'm being lazy but will go back through it.
Buffalo, NY
2020 Magnetic Gray ST w/ Street Pack
I've been following this thread since the prospect of purchasing a exst, I'm proud to say i am an owner of one... anyways.. this was the first thing I did and it got me thinking, wouldn't there be some way to trick the sensor into thinking it was Daylight all the time in hopes it would enable you to use the auto function as parking lights, I tried disabling the sensor but it didn't work
rusty0116
philadelphia
2022 Ford Explorer
hey guys, just wanted to check if anyone finally figured out how to disable the white DRL strip and use the amber turning signal as the main DRL without any issues using FORScan, or any other solutions?
Hans
United States
2025 Ford Explorer ST-Line
I just got the ODBlinkex and sign up to Forscan. are the values or sequence to
change DRL/ turn signal same for 2025 ST Lines?
alkh
Ottawa
Ford explorer 2020
Hi, i’m new here and i have a 2020 ford explorer and i’m trying to turn off the DRLs and have the amber light on, could anyone please help me personally? like make a video or something? like a step by step on what to do. please let me know any help would benefit.
North West
Welcome to the forum. This has been posted a lot! Run a search and you will find the information. I haven't seen any videos but lot's of threads with the instructions. Here is one: https://www.explorerst.org/threads/interceptor-amber-drls-on-explorer-st.1559/post-94110
Ottawa
Ford explorer 2020
I’m just a little scared to play around with the settings and probably a video of everything would be a lot safer to follow, thanks a lot tho!
Bonaire, GA
You can modify the front signal lights to be DRLs in Forscan, however I haven't figured out how to turn the actual DRLs off.
So.. spent 3.5 hrs trying to figure out how to turn off the LED bar, and turn on the orange turn signals to DRLs. Finally, got it all changed and working, and like you said.. they do not flash with turn signals.. just the mirrors and rear. That being said, we are going to meet up with a Lt LEO that has a '22 LEO explorer and plug into it. Fingers crossed, we can find maybe a different code from his to change in mine, to make the flashers work up front.
Did you go to the link that I referenced 5 posts earlier? It turns of the LED DRL strip and uses the turn signals as your DRL... and the turn signals still work. At night, it's just the headlights. To me, that's perfect.
