Fullscreen Android Auto/CarPlay Mod Is Here for Sync3 10P Screen!! [FMods Team 10 Pees]
Round Lake, IL USA
For some reason I haven't gotten an activation email yet to log in. It said it could take a few days so maybe thats what im waiting on. Hopefully so.
Check your spam. Looked for mine all day when I thought to check there.
Round Lake, IL USA
Saw this initially on the FB group and thought it was too good to be true. Waiting for time this weekend to sit and get this installed. Even Alpha it can't be worse then normal Sync issues lol.
Jailbreak is very timing dependent. I would recommend you hook up a battery charger (if you don't want to keep the engine running) and use Forcan to initiate the reboot so you can time it better. I used Forscan Lite with my iphone. Still took 10 tries for me.
Round Lake, IL USA
Good call, gonna have the laptop out anyways for the usb drive so might as well. Thanks for the tip.
Not a matter of couldn't but that they just didn't want to. The crazy thing is, all of the code to do "fullscreen" projection is already part of the binaries they included in Sync!
I think the industry term is "we will fix it in version 2"....... It also didn't help Sync 3 was DOA when the Explorer was redesigned in 2020
Canada
#26
@ilovepancakes How do I get this screen? When I cycle through the different screens, I only see one with three apps at the bottom and the map at the top. I prefer this one because the map is larger, and the two apps at the bottom are smaller.
Btw awesome work! So far I am loving it.
Using my wireless Carplay dongle, I am getting frequent disconnects. The device does not feel warm so am guessing that it doesn't have the processing power needed to handle the full screen map and music active. I went back to wired and all seems fine--maybe less laggy as well. Again, I am blown away by the full screen Apple Maps.
poLuz
Poland
Ford Explorer PHEV
to switch the view use this button in the lower left corner, which changes its icon
Charles Town, WV, USA
#29
Got it all working yesterday. Had a little struggle getting the first file in but once I did that it went pretty smooth. I gotta say I'm super happy with this update. This is what the ST has needed for so long. You guys did an awesome thing here! Can't thank you enough!
Round Lake, IL USA
#30
So stoked to try this over the weekend. You guys needed 4 thumb drives for the software files?
I
United States
21 ST
Thread Starter #31
Which make/model dongle do you have?
It's called Mavlou and bought a few months ago--previously was pretty solid with very few disconnects. Now I'm not sure that's the problem though. I just had two disconnects in a short period of time WIRED. It'll disconnect from Carplay and then 3-4 seconds later will reconnect like nothing happened. Will reboot my phone (iphone 14 pro max, iOS 18.3) and SYNC... observe some more.
Update: changed wired lightening cable (from previous Etsy cubby mount) and connection is rock solid. definitely less lag wired compared to wireless. Would definitely recommend others so this.
