Fullscreen Android Auto/CarPlay Mod Is Here for Sync3 10P Screen!! [FMods Team 10 Pees]
Dallas, TX
I registered on the 5th, never received an activation email. I clicked on the resend activation email button and a message states no username/email matches. Is there a restriction on free email domains for registration purposes?
Charlotte
#62
This is wild going to attempt this, thanks for all the hard work!
Anyone else go through all the correct motions and it not work? I did everything exact in this video except format the drives since im on a mac. All loading screens showed correct and the same as the video. I tried both USB and USB-C ports. Carplay is still showing on half the screen. My sync is 3.4
You can still format your USB drives with MAC. I used my macbook and formatted them to exFAT. Regardless, if the steps all progressed as planned except for the final usb (fullscreen mod), try and look at the log to see what it says. Also Sync 3.4 version needs to be 23188
#66
Same thing happened to me. I re-registered and got the email in about an hour
Dallas, TX
I tried that right about the time of my previous post, no luck. I'm rocking a 25 year old hotmail.com email address as my primary personal email, so I set up an alias with an @outlook.com domain and used that. I got an activation email instantly. I guess they don't like hotmail.
Thank you. Looks like i wasnt up to date. So can i install the latest version (23188) and then plug USB #4 back in and reboot?
I
United States
21 ST
Thread Starter #69
My logs look the same and I am on 23188.
New version of Beta2 released that should help with these issues when coming from alpha. See Telegram Sync 3 Mods & Apps Thread. Try it out and let us know. Make sure to have your original stock files placed in backup folder of new beta2 before running.
Canada
#70
I just tried it and am getting the same errors as the previous beta2 when upgrading from alpha. Stock files were placed in the backup folder correctly.
Canada
#71
Got it working thanks to the guys on Telegram. Thanks for the hard work on this! :)
Since we seem to have similar issues, what was the solution?
Updated sync version via USB then went went through the 4 mod USB again and it worked. Thanks!
Southern New Jersey
Did mine last night on my 2020 ST no issues. The best way to get the jailbreak to work on mine was to start to hold down the buttons and insert the USB at the same time and as soon as it reboots remove the USB. Tired the insert first and reset did not work.
