What's This Noise?
Suprawill1
Hi All,
As of recent, the ST has developed a whistling sound. I don't think it's turbo related because it happens below boost rpm. It seems to come up when I'm cruising around 35-40mph and tac-ing between 1100-1300rpm. It gets a little louder with load but seems to be the only place it happens. Any thoughts? I'm hoping it's not transmission related.
https://youtube.com/shorts/2VlY0NEu9fA?feature=share
Desert South West
I had the same noise with a car, turned out to be a wheel bearing, but it cut in around 55-60 mph. Have any of the tires brushed against a curb recently?
Hi All,
I noticed a different noise today on mine at highway speeds.
https://youtube.com/shorts/xS2oTLMu7XQ?si=XxCJRJeBuzJB5L6H
Wtf, that would drive me nuts! Possibly a vacuum leak somewhere
Mustang0712
Reno,nv
2020 Ford Explorer
Do you have a oil separator? If so check the fitment. Could be coming from a disconnected line or possibly another vacuum leak some where.
I'm totally stock, no mods.
Mustang0712
Reno,nv
2020 Ford Explorer
Check your stock vaccum connections. Other then that I would have to hear it. Sorry I couldn't help more
I noticed it at speeds above 40 mph. I don't hear it at slower speeds.
Mustang0712
Reno,nv
2020 Ford Explorer
Under load or just above 40?
Suprawill1
Suprawill1
Yes, coming out of the drive through at the bank, there's a hard left turn and they didn't make it wide enough for an ST to traverse without brushing the front right or rear left tire. I'll have to check on that.
Thanks.
Suprawill1
Suprawill1
Suprawill1
Suprawill1
That's a thought!
Suprawill1
Suprawill1
That'll be attended to the next time under the hood.
Thanks!
2022 explorer st
Did you solve this issue?
Suprawill1
No, it kind of resolved itself.
Funny, it seemed to happen on the same street more often than not. Might have happened maybe one time after I started this thread and hadn't heard it since.
