Lowering Springs Pros and Cons
Jack it up, loosen the UCA/frame bolt and gravity will do the rest. Then go get the toe set.
Well heck, that sounds easy enough. We’re gonna work on it one night this week. I’m going by the other shop tomorrow and see what they say.
I'm more than likely going to put a Traxda lift on my Explorer. I sure as hell hope I don't run into this same alignment BS afterwards.
Charles Town, WV, USA
So I'm having the same issue now too, lowered it Saturday, took it to the alignment shop, showed them the print out you made Bruce, and they still couldn't get camber into spec. I don't have the exact measurements but rear camber was like -1.8 on both sides. I didn't want to argue with them but sounds like he didn't do something right. Taking it to another friend this weekend to see if we can get it closer. My question is will it cut tires at-1.8 if I drive it this week? I hate to have to borrow a vehicle and weather has been shitty here on the east coast this week.
Camber doesn’t really wear tires…toe does.
Good deal, thank ya as always sir, side note the Lethal springs feel great, wish I'd have done this two years ago. Now she needs some Vossens lol.
Canby, OR
What a f-ing shit show! I just had new tires installed and a 4-wheel alignment. This is what I told them:
1. Jack up the rearend to take the weight off the wheels.
2. Lossen the camber adjustment nut 2 full turns.
3. Let the suspention settle and re-torque the nut.
4. Put the car down and check camber (which should be close to -.5°)
5. Adjust camber if not -.5°
6. Adjust toe to -.1° or just below.
The guy said when he checked the camber it was out of the spec I told him and he couldn't adjust it enough to get near -.5°. When he checked the camber after setting the car back down it was -1.4° and -1.7°. As soon as he loosened the nut to adjust it, the camber jumps back to -2.4° and -1.8°. So I told him to redo it and leave the camber where ever it falls and just set the toe. It ended up settling at -1.3° and -1.8°. The toe was set to 0.11° and 0.13°. Is this close enough? What else could he have done?
I’m going to be doing this today. A friend is coming over to help me and we’re going to jack up the rear end to get the weight of the wheels then loosen the nuts and let it settle wherever it will. I have an appt on Monday for an alignment. I’ll see how it goes.
So did anyone else have a really bad creaking sound right after the install? I can't imagine its normal but mine creaks and groans at low speed and over bumps like crazy now. I think somethings out of wack. I can't see anything obvious but... am I missing something?
Probably a rear spring not centered in the perch and rubbing on the LCA.
I'll have to jack it up this evening and take a look. Should be an easy enough fix at least if thats all it is.
Use a mirror to look down into the spring pocket…it’ll be easy to spot if that’s it.
update, thats what it was, the clocking was off by maybe half an inch but it was enough it was making contact, Twisted it where it needs to be and now its quiet. Thanks for the help!
Toadster
Folsom, CA
What are the lower control arm mounting bolt torque specs for the steeda springs? The instructions say to look up those manufacturer specs. I just can’t find them. I think the guy that installed the springs and sway bar tighten those bolts while I was up in the air not on the ground.
Dallas, TX
Toadster
Folsom, CA
thanks so the lowers are 66 ft-lbs and 180 degrees
only the rear is squeaking, maybe not enough lube on the swaybar too? i wish the steeda bar had zerk fittings to add grease :(
Dallas, TX
Sorry I didn't see where you specified front or rear of the vehicle. It's gets confusing because the front end has both front and rear control arms.
I don't know if one or all of these apply to your question.
Charlotte
I made this sheet using the info from this thread. Does it look correct? I want to take it to another shop I found that is supossed to be good.
Thanks, had to use this with my alignment shop that was super confident there is no way to adjust rear camber. They later complained "why don't they use eccentric bolts it would be easier".
It took me going to three shops before I found one that would follow the directions. I took the print-out to the original shop and showed to the manager. I told him the kid never touched the rear camber and he gave me a 50% refund.
