Tpms relearn 2020 ford explorer st / black wheel
Jc12205
Saratoga
2020 Ford Explorer st
I
The car will relearn after a few minutes of driving. I switch to winter rims and don't have to do anything.
J
Jc12205
Saratoga
I guess you didn’t read or understand my post
Any 315mhz TPMS will work and as mentioned above all you have to do is drive a few miles. Yes I read your post….you don’t have to do all that stuff.
J
Jc12205
Saratoga
I guess your the expert I driven with ford Tpms60 for 2 weeks and tried all reprogramming techniques. And all your suggestions failed . But since you know best I should just take my experience down and not give readers other options. .
If you ask pretty much anyone here who to ask about wheel and tire questions…they’re gonna tell you to talk to me. Expert? Nah…but I know a thing or two.
Sounds like you got a bad sensor…because again, no relearn or set up process is required other than install and drive.
Next time you need a sensor just grab one for 10 bucks off eBay instead of paying Fords high prices for something they don’t even make.
I'll second what UNBROKEN has said. I have another set of 22" wheels I had on my 21 ST that has summer only tires on them, I would swap the factory 20's back on for winter and I never had to do anything but drive it for about a half mile and by then all my wheels were synced up with the car. When I had the tires mounted on the second set of wheels, I bought a whole set of ford racing TPMS sensors for 150 bucks from american muscle.
BTW way back in 13 my wife had a 2012 focus and my daughter had a 13, well the wife liked the dark stainless color of my daughters wheels and my daughter liked moms polished wheels so I swapped them and neither car needed training of the sensors, they just worked.
Guy deleted his post…is that the internet equivalent of taking your ball and going home? lol
I guess some people don't like to be proven wrong.
I trust your knowledge and just want to be 100% sure because I see some others say the 2020's had either 315mhz or 433mhz. I tried checking with my vin but didn't get anywhere. When I Google them I also get 315 and 433 mhz. I just want to be sure I get the right ones.
So I found these. There are some cheaper and some a lot more expensive. Any reason not to go with metal instead of rubber besides price?
I just replaced one with one with the metal collar (similar to the one pictured). It is much more noticeable in the black stock wheel. If I were to do it again, I'd one that is just a black rubber stem.
I was going to go with the gray because the rims I’m getting are gunmetal. Is your only regret because of the color?
yes. but if they match your rims, it should be a non-issue.
