PIU rear sway bar
WA
Tried search, didn't come up with much.
Would upgrading to PIU rear sway bar be a worthwhile upgrade? It's about half the price of Steeda/AFE. Direct swap with ST hardware?
Thanks.
Can't answer the question but one thing to consider is that the PIU one is not adjustable.
The midwest
The PIU rear bar is in between the ST and Steeda/AFE bars, so of course it’s an upgrade. There are a few threads with comments on the PIU parts already. The PIU rear shocks are also allegedly stiffer, which could be a great combo to cut down the understeer. I have these parts waiting to go on mine since I’ll be removing the rusted Steeda bar. All said and done, the PIU bar & shocks together all came in around $350, FYI. Not a bad deal at all.
R
WA
Good point. Although I would probably just use the middle setting.
R
WA
Yeah, solid deal. Are you leaving the front struts stock?
The midwest
Yes. I want only the rear to be stiffer since that’s the way to trim down some under-steer.
True, but a thicker bar is still going to tighten up the rear over a stock bar, just not to the extent of an adjustable bar. The difference may be minimal anyway, but I’ll know soon enough when I make the swap.
New Jersey
Has anyone tried the PIU bar yet? A good amount cheaper, no worries of paint flaking in salt areas, and no potential squeaking / fitment issues. Seems like a win?
also can someone confirm the part number for it? Is it LB5Z-5A772-C?
The midwest
Have had the PIU rear bar and matching shocks on for a couple months now. Nice improvement and even better that it isn’t going to rust out like the Steeda bar. You have the correct p/n.
Thank you. Ordered, 138 to my door
Jessup, MD, USA
Do you happen to have a visual comparison between the OEM and the PIU swaybars? I'm assuming the PIU is thicker?
@jwuonog It doesn't look much different but it def weighs more. here is my video.
The midwest
I’ve mentioned the sizes in other threads. Off the top of my head, the OE bar is around 21.5mm and the PIU is 23mm. Not a ton larger, but still an improvement in stiffness. All the bars have tags on them in the middle that shows the diameter.
