2023 ford explorer st
I’m looking to purchase the whipple intercooler, fenbfab v2 intake and the cvf downpipes. Would i also have to order a charge pipe with or without the BOV port? And is there anything else needs to purchase along with intake Do you guys recommend the hot side charge piping?
The Whipple intercooler is way more expensive then the CV-Fab intercooler which performs the exact same. The 2023s don’t have a factory BOV, so depends if you want to add one or just go without it. If you’re going to tune the car, hot and cold side charge pipes will net some gains, although not worth the money if that’s all your going to do.
Kiing.brett
Definitely looking to add a BOV. What you recommend and which charge pipe if needed.Once i get everything done i will 100% be getting it tuned. Only thing she got rn is the 3” thermal
Kiing.brett
If i go with the cvf intercooler i see there is an option for cold pipe kit ,hot pipe kit or both?
