Just to clear up a few misconceptions, the first gen Edge had a 5x114.3 pattern and a 70.5 hub bore up to 2009. The 1.5 gen, 2010 to 2014 used the same 5x114.3 pattern but went to a smaller 63.4 hub bore, they both used 1/2" wheels studs. In 2015 the all new 2 gen edge came out with a new smaller 5x108 bolt pattern and now uses the larger 14mm studs. These wheels will not work without major rework.
The Explorers have always used the 5x114.3 lug pattern, from the original in 1991 all the way up to 2025. the hub bore has changed over the years, the 3rd and 4th gens 2002 to 2010 used a 70.5 bore. In 2011 when the new 5th gen FWD ex came out they went to a smaller 63.4 hub bore. The all new 6th gen 2020 to 2025 went back to the 70.5 hub bore. All explorers from 91 to 2019 used a 1/2 wheel stud, in 2020 they changed to a 14mm stud.
