Eibachs Installed on my ‘25
Bran1093
Moorestown, NJ
Hey Y’all
Got some time to install the Eibach springs on my ST. Install was a breeze thanks for HSF install video!
RusW1
Missouri
looks really good. Do you like the stance? Does it sit level or maintain a slight forward rake?
Gainesville GA
25 Explorer Active
Looks really nice! How’s the ride quality so far? I’m about to lower my Explorer too, but I’m stuck between Eibach vs H&R springs.
Hey Y’all
Eibachs will sit very close to level, and lower the car the most compared to other lowering springs.
From what I’ve heard, Eibachs ride the best.
Charlotte
I have the set sitting in my garage to get installed, can't wait!
Coloradostan
It has been my experience with eibachs that they have a butter smooth ride, but in no way floaty and in every case help a lot with squat and dive. Iv'e installed 4 sets on 3 diff brands and all seem to settle more than expected, to be clear that isn't a bad thing in most cases.
Is that the case here? did you get what you thought or after a month do you find its lower than truly expected? Also what are the wheel measurements and tire size? Pls and thx.
eidt - Also, about alignment, specifically camber, can you drop a 2025 on eibachs and still have enough oem adjustment to keep it within oem spec? or are other suspension components needed (eg, high offset balljoints and the like)
Any competent alignment shop should be able to bring alignment to OE specs with the Eibachs.
Illinois, USA
Have to replace the struts and been wavering on which springs to go with since i'll be in there. You may have sold me...though I was moving towards the E's. Had a couple sets in the past that I was always happy with. Nice color too!
Coloradostan
Good to know.
Just to be clear, this is my first vehicle of this type, as well as my first Ford. Every previous eibach install has been on sport sedans or hot hatches (VW, Honda, Scoob), so there is a fairly low tolerance before reasonable tire saving, alignment adherent type actions are best implemented. I'm still learning what is "excessive" for this platform. If you know about eibach, you know about the raceline springs, the red ones. On a 2001 Prelude, prokit? (black springs) great! Raceline? (red springs) . . . . . naw dawg, I'll take my car . . . .
I realize at this point my comments are best moved to a suspension subforum, but I am still interested in the whell measurements, most specifically offset, rim size and width, and tire size choice. Bran, it looks good, let us know.
Good to know.
Yikes that reply is all over the place. What are you talking about?
