My take on the Aviator screen swap.
Sneak peek at my take on the Aviator screen swap. I took my idea and a spare screen to a friend at a high end audio shop who specializes in trim work…this is where we are right now. The whole bottom was cut off the screen I’m going to use then the top was cut off the spare and blended together. The rest will be trimmed in black acrylic. The 3D printed bottom trim options just weren’t gonna work for me. This is certainly not a cheap option…worth it to me though. att.ClYL0ucsVodgFctmmpXED9o_DkCQpqXCBcG760DhNOU.jpeg att.WwjHmOpZsAlGhcXsIicUH6UOeusKSSVIqMMhEK-6E-E.jpeg att.pb3_DHRN6Hb1Fi20qgV0zU-Ve7taXqWWJMZ6p5oKf_U.jpeg
Ct
25 ST
Impressive dedication and vision to your mods.
Something tells me this isn’t your first rodeo.
A few more pics of the current state. I’ll add more when the last trim piece is done.
if you look close at the shell you can see where the 2 were bonded together. Having a laser on hand to make the cuts perfect helped a lot. att.G3OvpP6NjGPhpiAXH_dVIJfANyEvE7Epqw0GJQTs-hQ.jpeg att.IuerUPx4EHausbbkLveqUAr950I3VPCXfJ-6KDPuAsI.jpeg att.kgHQJg_VQcOTzV-ovWX7qPI7xlJ52NSMaIEdOW-RNno.jpeg
San Rafael, CA
Very impressive. Looks good. I don't suppose these will be something other forum members can purchase?
Also, is that a F100 delivery in the background? Can we get a tour of that too? :D
This will be cost prohibitive for anyone with a brain in their head. It’s definitely not something there would be a market for to sell I don’t think. Buying two screens plus labor you’re probably at near $1500 unless you get the screens for dirt cheap.
If you remove it you would have no trim around the edge at all.
Finally had time to get this thing installed. Everything is doing what it should and I’m headed over to see Travis at Houston Speed freaks now for the foreskin changes since my license expired. I’m almost done with the trim piece to cap the bottom but I just haven’t had time to work on it.
Forscan mods complete. All is well…everything including massaging seat functions are operational on the screen. It does appear that the ambient lighting color list is wrong…I never change it anyway so not something I’m worried about. IMG_6192.jpeg
Ct
25 ST
Looks great.
That came out very nice.
Finished up the bottom cap today. I took the other housing I had and cut it into 3 pieces, CA glued them together then hit them with some epoxy to make it solid then a little body filler to shape followed by adhesion promoter, primer and paint. Honestly I didn’t even try to make the filler perfect…nobody is ever going to actually see the bottom. I just wanted it smooth for when I’m reaching into the tray under there.
I may at some point play with my own mount to move the screen closer to the dash. It looks fine as is but I think it would look better about an inch closer. That’s a project for another day though.
Fairfax, VA, USA
That does look really slick. I’m a lazy mofo and still have my screen zip tied in from when I was test fitting it a year ago. never even thought about using trim from 2nd screen to make the bottom. Time to call junks yards looking for a broken screen.
Thread Starter #18
Unbroken, how did you mount yours? Aluminum stock?
secondly, does the radio presets work on yours? Mine won’t show presets or let me save new ones.
I used the printed mount from Dariusz Kedzior.
All Sirius presets work fine I haven’t used terrestrial radio in a decade or more so I haven’t even tried those att.QJDikyYhN4zgJf1KBC8oV6105o9jeYZpF5I7duuiV0g.jpeg att.WHncwQSG_6uO6NP96lT3fh0OuHdhr7TqGBjAHEukyak.jpeg
Darius’s mount looks good.
if you could try the terrestrial radio, just out of curiosity, let me know.
secondly, did you have to manhandle the factory plug to get it to fit in the correct direction with the screen? On the aviator panel, my factory plug faced the opposite direction so I really had to wedge it against part of the monitor mounting brackets. No big deal but didn’t love it
Thread Starter #20
Presets work just fine on all sources
