Front end thunk
Arizona
2020 Ford Explorer
This morning my car started making a thunk sound from the front. It doesn’t do it every time but it mainly does it when I’m slowing down and almost at a complete stop. Took it to the shop they said they couldn’t see anything wrong. Kind of hard to hear but I took a video from inside the car and you can hear it. If anyone knows what this could be please let me know. Thanks.
https://youtube.com/shorts/W1EStHI7x4g?feature=share
Are you hitting any uneven pavement? If so I would say sway bar end links or top strut bearing or strut. Seem to be common problems. If it’s when you hit the brakes possibly a loose caliper bolt? Just guessing here.
M
Arizona
2020 Ford Explorer
I don’t think it would be the pavement it’s the same places I drive everyday. The shop inspected the brakes and said everything looked good with them and didn’t notice anything else that would be causing it. So I’m at a bit of a loss trying to figure it out.
Sarasota
I have something similar going on. Ford couldn't find anything but an independent shop found that the tierod end links were worn and probably making the noise. I haven't had them replaced yet but it's a possibility.
23 Explorer ST
I had that same clunking noise. The first time I had it at the dealership they replaced both struts.
Didn’t even make it a day and the clunking noise returned.
I finally got it back to the dealership and they stated the struts wasn’t the problem but the sway bar end links had some movement and they replaced both sides.
I picked my Explorer up this morning and so far no clunking.
Hopefully it will stay that way.
2023 Explorer ST, Rapid Red
M
Arizona
2020 Ford Explorer
Good to hear about the struts, after reading through this forum that’s what I was leaning towards. I will look into the end links thanks.
23 Explorer ST
