hi all good morning
대한민국
2023 링컨 에비에이터
Owners, what is the right product for ignition coils? Tuning? Ford? Good maker recommendations
Use the Ford coils, don't replace them unless they are bad.
Is only use the Ford ones. Do they need to be replaced?
포드링컨
대한민국
2023 링컨 에비에이터
No, I'm just curious. Then I just need to change the ruthenium plug, right?
포드링컨
대한민국
2023 링컨 에비에이터
There are good Platinum, Iridium and Ruthenium plugs available, saying one is better than the other is easy to do, but hard to prove. Either could serve you well. Spark plugs are a consumable part, making sure they aren't worn (increasing gap, electrodes no longer sharp) is the important thing.
Remember what you are getting with these high-end plugs are plugs that were designed to be run longer, better wear resistance. Most enthusiast find themselves changing plugs because they feel the need as opposed to there actually being a problem.
I run NGK Ruthenium plugs, they have served me well in all the turbo engines I've owned. I've never pushed a set to see how many miles they would actually go. Mine never see more than 20,000 miles, I'm sure they'd go much longer.
포드링컨
대한민국
2023 링컨 에비에이터
There are good Platinum and Ruthenium plugs available, saying one is better than the other is easy to do, but hard to prove. Either could serve you well. Spark plugs are a consumable part, making sure they aren't worn (increasing gap, electrodes no longer sharp) is the important thing.
Thank you for your good reply. If you look at the forum, I use the recommended plug ruthenium column number 6,95605. If I look at the manual, shouldn't I use column 7.90495?
Which catalog are you looking at? Is yours a Hybrid or just a gasoline engine?
포드링컨
대한민국
2023 링컨 에비에이터
t's just gasoline
90495 - LTR6BHS is what NGK lists for your vehicle. If you are tuning, you may wish to look at one heat range colder.
포드링컨
대한민국
2023 링컨 에비에이터
Thank you. I'm asking because the car is high power
