Mapping Not Working
Wingrider
Missouri
On my 2025 ST, when I go to My View, then Map View, on the instrument cluster, I now get "Map Source Not Available" instead of the map. Mapping works fine on the info display, but just stopped working on the dash. Any thoughts?
Beedata
Miami
Hello, my wife had the same problem with her 23 ST. The dealer did an update to her infotainment system and it corrected the problem. Hope this helps.
DaGooch
Illinois
I checked my 25 this evening and the same thing! It was working fine at least 2 weeks ago.
W
Wingrider
Missouri
Well, I guess the good news is that it may be a system wide issue, and not something unique to my ST.
St. Louis
My maps is functioning correctly as of this morning.
W
Wingrider
Missouri
I see that you have a 2021 model ST. The problem may be unique to our 2025 model.
SoySauceSoakedSaltine
South Carolina
Interesting, do a system reset holding the power button that's within the volume knob for 10 secs. I am unable to check and see if I am having the same problem because the truck is currently getting paint corrected, ceramic coated and I wont get it back till the 2nd.
St. Louis
I have a 25, traded the 21. Need to update. My b.
W
Wingrider
Missouri
Great suggestion! I tried it and it worked. Everything is back to normal. For those with the same problem, while the ST is running, put it in park and push and hold the power button which is the center of the volume knob. Everything will go black for a few seconds. Then it will reload and power up. I did not lose any data. Thanks again for the suggestion.
DaGooch
Illinois
Confirmed! I did the same thing earlier today. SouSauce thanks for the heads up!
Dr. Benz
Plano, TX
2025 st
This procedure worked for me as well, Thank you!
Stever
Tuttle OK
Happened on my 2 week old 2025 an the procedure worked great for me as well. Now the question is this a permanent solution or does this problem come back every few weeks?
DaGooch
Illinois
It's been about a full month for me and it still displays correctly.
W
Wingrider
Missouri
Since my original post on March 30, I have had no repeat of the problem...until yesterday. I implemented the same fix as before, which worked fine. However, this may be a recurring problem.
