That is going to tuck in a lot. I have a set of 20x10's for winter with a 40mm offset and although they come out a bit more than the stock 21's, they still need about 7-10 mm less of offset to be flush.
With a 6.5" wide wheel and that much offset, you might need to check clearance on the inside.
