TNSmokee
Collierville, TN, USA
Thread Starter #61
She's actually thinking about it, woo hoo!
DoingOK
Smithfield, Virginia, USA
#62
Once again, Thanks. I'm sold and if it was my daily driver then it would be no question. It's hers and she doesn't spend it quite like I do. The rim website is saved as a favorite and the tire of chose is the Continental ExtremeContact. Those tires are around 330.00 each so I may need to ride the originals for a little bit. I want the setup more flush and the spacers that UNBROKEN turned me onto are close but the wheels are going to put ME where I want to be, but again the ST is hers.
Continentals are great tires as well. I had them on my C7 Z06. I ordered 3mm hubcentric spacers for the rear wheels in case I need them after lowering. If you look at my pictures below, the front wheels sit out more flush than the rear wheels. They look fine as is, but I'd like the rears to come out a bit more. Those are 295x45 tires on the wheels I showed you.
TNSmokee
Thread Starter #63
That looks great to me. I love that color too.
You can dial in the fit with the alignment. I set my rear camber at -.5° so the front and rear are both flush.
DoingOK
#65
I remember you mentioning that. Hopefully we can dial it in......if not, I'm ready. Thanks again.
Clarksville, TN, USA
#67
Added the red carbon fiber start button, redid the black ST inlay, finished my adjustable swaybar endlinks and went out this morning testing and pulled a 4.03 0-60 on the Dragy.
Wow, 4.03 is great! What mods/ tune you running?
TNSmokee
Thread Starter #69
Added some overlays, although the "EXPLORER" is actual lettering and not just vinyl.
Toronto, ON, Canada
#71
Nice job. How do you think it turned out?? Are you happy with the results? Did you install your down pipes?
Toronto, ON, Canada
#72
Just saw your IG post. Nice job man. That was the right route to go
I’m happy as hell with it. Gonna need to do some sound treatments in the back...I can hear it when I’m driving. Not drone...just sound from the very back. Treating the liftgate and spare tire well with some CLD and CCF should do the trick.
Honolulu, HI, USA
#79
Nice projects. Thinking about painting calipers to match body color. Not sure how difficult and whether it would look better than original red.
TNSmokee
Thread Starter #80
