Anyone else have difficulty installing the Ford Explorer crossbars on their ST? I previously had a Ford Explorer 2017 Sport (ST predecessor) and had no issue installing the crossbars myself, and so I thought it would be similar. Different story with the ST. I can get the one side locked in but the other side won't fit into the side rail to lock in (see circles on image). It's almost as if the cross bar is too long. I could take it to the dealership to install but I like to have the ability to install and remove as needed. I also checked to make sure they are facing the correct direction, in the correct order, and also checked the install guide which says Ford Explorer on it.
