Sync Screen Glitching/Flickering
Jgrabina
Coram, NY, USA
Usually happens on a cold start up...the screen will flicker and bounce for about 10m. It is quite annoying. Any one else having this issue? Has the dealer been able to correct for anyone? Even does it after you turn off the car. See other video - dark screen, but the top flickering.
Definitely not normal. Have your dealer fix it.
Jgrabina
Jgrabina
Coram, NY, USA
Dealer replaced a “module” and “pigtail”, but on the way home it glitched again. Very frustrating. Called them and they are contacting Ford for next steps to correct the issue.
Symetry
West KY
I sure hate to hear that's happening, but I'm confident that Ford will take care of it.
I have 3 dealers I'm my area , some I respect their abilities more than others...just saying.
Hope you get it resolved soon.
Jim
Jgrabina
Jgrabina
Coram, NY, USA
**Update** Dealer contacted Ford and has fixed it. Replaced another part and so far, so good!
Do you know which part?
Reminds me of the TSB:
FORD TSB #SSM 49245
Some 2020 Explorer/Aviator vehicles built on or before 30-Sep-2020 may experience an intermittent or constant blank/black screen on the center infotainment display due the low voltage differential signaling (LVDS) cable at the SYNC accessory protocol interface module (APIM) not being fully seated. Verify that the connector is fully seated into the APIM prior to performing any other diagnostics or repairs on the vehicle for this concern. If the connection is found loose, re-seat the connection and retest.
BillST21
San Antonio, TX, USA
Thanks Jgrabina,
I had been searching high and low for the cause and solution. Your Video "9B4C2010-1903-4194-AD4E-E34507EAA0F7" illustrates exactly what I am experiencing. I have a 2021 built in August '21. I took the vehicle in once and they could not confirm the issue. I have taken a couple videos and sent it to them but that Service Advisor has since departed. The major difference between mine and yours is that mine does not do it right away. I might be on the road for 15 minutes before it happens, and it does not happen all the time. For awhile I thought there was some RF interference from external sources.
Anyway, I have a schedule visit this coming week for the Blue Screen Recall, which I am not experiencing, when they will look into the Screen Flicker Issue. I will instruct them not to perform the Recall will show them your Customer Receipt and the Video for their information.
Again, thank your very much!
Jgrabina
Jgrabina
Coram, NY, USA
Thanks Jgrabina,
Glad this helped! So frustrating when it happens and you don’t know why. Glad for the forums.
msokes9
Boston, MA
Just picked my 2023 ST yesterday as a buy back vehicle for this same issue that they said they “fixed”. Unfortunately a within an hour driving home from the dealer ship the screen started flickering. I’m bringing it back to the dealership next week and I’ll show them this paperwork for the correct part. Thank you for posting this, much appreciated!
Hope they sort it out for you.
