JACK POINTS
Punta Gorda, FL, USA
Am I crazy or is there know where you can find proper jack points and procedures to lift your ST? Looked at web until my eyes fell out. I can find every vehicle built except a 2020 explorer. Don’t get me wrong I’ve lifted individual corners to replace wheels etc. I’m going to order a Quick Jack for the C8 and would like to use it for both vehicles.
STJIM
(no where) dang auto spell!
There is no front center jack point. The rear differential can be used for the rear.
STJIM
Thanks but I’m looking for the side jack points.
Grimsby, ON, Canada
If you get down beneath the vehicle you will find arrows pointing to where you can place the jack. Just behind the front wheels and just in front of the rear wheels.
STJIM
I read that and I guess I’m blind. I guess you get that way a t 70 HaHa.
I’m guessing they go on the edge of the pinch points. Thanks going back out with brighter light as eyesight goes at 70 too! Thanks! Jim
STJIM
Thanks so much. I did find them and will be making an eye appt. tomorrow!
Jim
Grimsby, ON, Canada
Jim
get yourself one of these. Once you locate the spot at the pinch welds it makes it a little easier to locate the floor Jack.... POTAUTO Universal Aluminum Grooved Magnetic Jack Pad Jacking Puck Pinch Weld (0.39) Inch Frame Rail Adapter (Qty 1, Red) https://www.amazon.ca/dp/B078J55SBW/ref=cm_sw_r_cp_api_fabc_44tZFbPWQ753S?_encoding=UTF8&psc=1
STJIM
Thanks Frank! Just ordered 4 of them. That will work great using the new Quick Jack system. Jim
Dgoebel57
Faribault, MN, USA
2020 Rapid Red ST
Thanks to STJIM for bringing this up as it got me under my ST where I discovered that some dealership shop genius also couldn't figure out those (when you're under the side) well marked lift points and put their lift pads 4 inches forward under a (Not Intended for lift) area and damaged the protruding tab along that body/floor pan seam folding it over and cracking off paint. Damaged Body tab from Improper lifting of Explorer.jpg
Tape measure is in the proper lifting point section.
Colorado Springs, CO, USA
Thanks to STJIM for bringing this up as it got me under my ST where I discovered that some dealership shop genius also couldn't figure out those (when you're under the side) well marked lift points and put their lift pads 4 inches forward under a (Not Intended for lift) area and damaged the protruding tab along that body/floor pan seam folding it over and cracking off paint. View attachment 2853
Oh no, I have to now go check mine in the garage
Ok, just went and checked mine, They seem to have placed in in between the arrows. However, it is a thin portion, not a flat one. Is it where it is supposed to go. I am not sure if I am being clear with my question, it is like a thin metal area, like the folded edge protruding downand Not a flat one like I expected.
Dgoebel57
Faribault, MN, USA
2020 Rapid Red ST
The lift points are that edge you're looking at, if you look at the top of the Ford jack, it has a groove for that edge, the Potauto Adapter allows standard round plate topped jacks to lift without damaging that standing seam.
Ok, thank you, then my seam is slightly damaged, it has a split in the seam on one side. Either they should change the jack design or change the mounting points.
Grimsby, ON, Canada
Thanks for sharing, can you leave this installed in the vehicle or do you have to attach it everytime your dealer needs to lift it
They have magnets so they would stay in place, if you happen to forget them there. But I don’t think they would remain there permanently.
Grimsby, ON, Canada
No. They dealer (i know, I know) should know exactly where to place their Jack’s.
These I would suggest are for the home mechanic type. I found it helps to locate and stabilize the lift when I use my floor jack.
Thank you.
Waupun, WI, USA
And where would you place the jack stands? I haven't gotten under mine yet, but lifting is only half the battle....
