CR Performance has released a few more options for Explorer ST turbo upgrades!
The stage 3 includes a 46x56mm compressor upgrade
The stage 4 includes a 46x56mm compressor upgrade and 45mm 8 blade CR Performance MAR-M turbine
The stage 5 includes a 46x56mm compressor upgrade and 50mm 8 blade CR Performance MAR-M turbine
Cost wise, there are 2 different ways to go about it, you can take your turbos off and send them in (normally a 3-5 day turn around plus shipping time) and have them upgraded or CR will use new cores and you can send your old turbos back to them.
the stage 3 is $1650 if you send your in and $3,160+$525 core if you buy a new set.
the stage 4 is $2050 if you send your in and $3,560+$525 core if you buy a new set.
the stage 5 is $2450 if you send your in and $3,960+$525 core if you buy a new set.
- Show All
