Hello all,
Has anyone made these changes with Forscan ??? :
Switch on the fog lights by turning the wheels
In the BDyCM module edit the line "Corner Light Mode for fog lights" and switch to Enabled
Set the number of flashes of the automatic flashing turn light instead of the 3 original flashes (in France)
In the AS BUILT Format SCCM locate the code 724.01.01 then replace the xxxx xXxx xx by:
0 = for 1 Flash
4 = for 2 Flashes
6 = for 3 Flashes
8 = for 4 Flashes
A = for 5 Flashes
C = for 6 Flashes
E = for 7 Flashes
Automatic door locking when driving from 20 km / h or 12mph (desactivated by default in France)
In the IPC module edit the line "Automatic door locking" and go to Enabled
automatic door locking function can be activated / deactivated from the ODB parameters (not existing by default in France)
In the IPC module edit the line "Self-locking configuration status" and switch to Enabled
Thanks,
Alex
0 = for 1 Flash
4 = for 2 Flashes
6 = for 3 Flashes
8 = for 4 Flashes
A = for 5 Flashes
C = for 6 Flashes
E = for 7 Flashes
Thanks,
Alex
- Show All
