"EXPLORER" lettering on hood
Gig Harbor, WA, USA
How hard is it to take these letters off? Does it leave lots of adhesive on the paint? What's the easiest and safest way to remove them? Heat em up and pop em off??
Just slice them off with some fishing like or dental floss then remove the left over adhesive. I prefer and use a 3M Eraser Wheel because it’s done in a flash but GooGone works too...just a lot more elbow grease.
mkuluz
Gig Harbor, WA, USA
How's it look? I think its a much cleaner look for sure.
I’ll pull the letters on mine. No way I want to be cleaning bugs out of the lettering over the next few years.
Grosse Pointe, MI, USA
It looks so much better off - i did this a few weeks ago using goo gone and it sucked lol - use the wheel
mkuluz
Gig Harbor, WA, USA
Hey...do you guys have pics of the before and after?
Jshaffer3819
Kaiserslautern, Germany
Is this the wheel you are referring too? Do you use it dry or with clay lube?
mkuluz
Gig Harbor, WA, USA
Much cleaner...thanks.
Would a heat gun help along with the wheel?
That’s it and you use it dry. O’Reilly keeps them for about the same price if you don’t wanna order and wait.
92onward
Active Duty U.S. Navy
Took me 20-30 mins.
-Spray Goo-gone on letters (let it sit for maybe 1-2 mins)
-Floss the letters off with fishing line
-Use adhesive remover wheel (I use Goo-gone as lube)
-Clean
Took me 20-30 mins.
-Clean
It took that long because you lubed the wheel. They’re designed to work dry...it would have taken you less than 2 minutes. lol
92onward
Yeah dry felt like I was gonna burn through the paint lmao
It won’t burn through the paint as long as you keep it moving and stay under 4000rpm. They were literally designed to work on paint, dry.
Jshaffer3819
Cool, thanks. I live in Germany so unfortunately I am at the mercy of Amazon prime. 10-14 days if I order now. I’ll check the German Amazon.
