Fuel octane?
Virginia
What octane is everyone using on a daily basis? Also I have a gas station with 88 octane I think it’s 15% ethanol I sure it safe to use every once in a while but does anyone else use it?
Arden Hills, MN, USA
I use BP 93 octane plenty of stations in my area. I did one tank of 87 and now 3 tanks of 93 now and the ST does run better on the higher octane, worth the extra cost per gallon. Like your ST's name
Symetry
West KY
So far , 2 months , I've only used BP 93.
Vehicle runs really good on it.
May try some 87 just to see how much difference.
Jim
St. Augustine, FL, USA
I started with regular but recently started using 93. The fuel mileage went up and the performance was more sporty...faster by my butt dyno. I may alternate some 89 in at half tank. It ran fine on 87 but seems to be worth the extra $ for the higher octane. Note that in the manual it does recommend higher octane in warm weather and when towing. I have to imagine it's a high compression engine and benefits from the higher octane.
Burlington, ON, Canada
I've run nothing but 87 octane since day one. No idea what the dealer pre-filled it with for me when I took delivery, although I'm willing to bet it wasn't high-test.
No issues running on 87. I have no doubt I'm down a few horsepower because of the lower octane and the engine auto-adjusting timing etc etc, but whatever power I have lost can't be a whole lot since this thing still goes like stink whenever I want it to. And for my purposes, which is basically commuting to and from work on the highway in a heavily trafficked multi-city area, I will never be racing it at 240kph or drag racing it on a regular basis, and if I ever want to tow with it or take it on a very hilly drive on a hot day I'll fill it with high test first.
Averaging just around 20-21 mpg consistently since day one.
Edit: Yes, now you may all go ahead and lambaste me for not using 93 octane. Go ahead, I'll wait lol.
LokiWolf
Henrico, VA
Difference in HP on Stock tuning between 87 and 93 is between 10-15 HP.
Also E10 93 is better than EO 93 for HP.
The 88 Octane flex is better for power(slightly) than 87, but slightly worse on MPG.
93(E10) is the best on power and MPG.
I'm not going to blast anyone for using 87 octane, mine ran fine on it. If the price of 93 octane goes through the roof, then I know it will run fine on lower octane. But if 93 is cheap, that's what I'll use...at a half tank I can top off with 89 and still be in the range of 91. I usually keep my tank close to full...kind of a prepper mentality.
I run an E50 ZFG tune using 50% E85 and 50% E30 (93 octane). E85 is about $1.59 per gallon now and E30 is about $2.10 ish.
Fairfax, VA, USA
I started out running E10 93 and for the last couple tanks I wanted to see what E10 87 was like as it is $3.29 vs $2.49 a gallon. Feels a bit sluggish, my overall fuel economy went down from 16.8 to 15.3 (most of my driving is suburban streets with lots of stop signs and lights so i have to be on throttle a lot more). I'm going back to 93 on my next fill up to see how it goes.
Fairfax, VA, USA
Man. that pic makes me cry on the inside with jealousy. I wish I had that pump here.
Fairfax, VA, USA
Thought about another reason to run the most powerful pump gas you can on stock tune. I am planning on putting a tune and maybe light mods around 5k or so miles to make sure that I don't have any big issues (Trans seems to pop up a bunch in threads). that being said, I should try to put the car under the stress closest to the tuned version to shake anything loose while I still have a warranty.
Sechelt, BC, Canada
Around here, the higher the octane the higher the price - what gives? Also,the higher the grade the less ethanol. I run high-test in my power washer and outboards to get less ethanol so it doesn't turn to garbage over the winter. Ethanol is supposed to have lower BTUs than gasoline? I'm outta here to do some research...
Va
I run super in all my ecoboost Ford's.
Merritt Island, FL, USA
I run 93
I had a Toyota FJ, and those are HO engines, they do not like low octane, changes timing and mileage
I figure the same here.
Sechelt, BC, Canada
I get it - tons of ethanol. Its not a true 93 octane gasoline fuel because it has so much ethanol and although you FF engine may like it, you are using more of it per mile therefore its not cheaper. We need the SAE document to determine the standards that Ford uses but I'm not spending $85 for it! 3F9DF534-07A3-47E7-88B3-92CCC922C3A4.png
LokiWolf
Henrico, VA
I get it - tons of ethanol. Its not a true 93 octane gasoline fuel because it has so much ethanol and although you FF engine may like it, you are using more of it per mile therefore its not cheaper. We need the SAE document to determine the standards that Ford uses but I'm not spending $85 for it! View attachment 5673
I gave you all the answers in your other thread. I have the document. I am well versed on the chemistry. Already answered.
I guess I'm spoiled since here in Eastern TN, we can get 93 with ethanol, 93 with no ethanol, E-85, etc. I do not have a tune yet, but I've used all of them. I have seen better gas mileage from the non-ethanol variety. But for an extra 1-2 mpg (highway) from my ST and my previous supercharged Jaguar XF, it is NOT a money saver since it's about $0.80 more per gallon.
edit: I did not mean to imply I filled with E-85!
Sechelt, BC, Canada
If you have the document, print the bit about the fuel? Your answer was not definitive.
